Stihl FS400 HEad keeps spinning
Thanks.. Would that be noticable?. I took the clutch off and had a gander but all looked intact. A minor amount of surface rust but fine.. I start wondering if its my throttle cable that's misadjusted.. When you say low speed I wonder if it is actually low enough.. What RPM should it be and what is best tool to test the same?
Is the cable loose when the machine is on tickover.
I'm thinking the controls have moved forward a bit tightening up the cable. Remove the throttle cable from carb and start it up. Will let you know if the cable is at fault as the throttle will be down to as low as it can without the cable influencing the throttle lever.
Basically remove the cable from the carb and see if it makes any difference. If it doesn't then the screw should be with the throttle lever on the carb. Easy to spot.
Then I wold look at clutch. Clean it up. If you know what to look for sometimes they show, a clutch part may out a little by looking at the space between them on the carb.
Sometimes it can't be seen.
Is the drum also ok?
