Strimmer carb screw
chainsawMal
A few years ago Stihl used a carb which only had one screw. The screw looks like a mixture screw as it is threaded through the carb body, but in fact it is an idle speed adjuster which acts directly onto the butterfly. The mixture on these carbs is non adjustable.
It is not possible to retune to compensate for wear and tear, but he later carbs with H&L screws can be fitted.
