Thanks, its all the functions on the leaver, give it a good tap and it works fine. Will hopefully get a look at it tomorrow before putting it back to work.
Will get back to you and let you know what's needed, if its not sold
  • 3 weeks later...
Drive to the Osa rear bogie went again, so bogie off this time and back to shed, found the center drive sprocket sleave had lost all it,s internal splines!
New one fitted see center of arm in photo, on top of arm at the right is the old one minus internal splines, New hub bearings will be here one Monday so up and running again on Tuesday:thumbup:
That's good, glad you're sorted. I've got a spare osa 250 for parts but couple bits are out the back already
Edit: In about 6 months time once I finish current/future jobs I'll probably sell my 250s and stroke processor, give me a shout if you want first dibs.
Edited by Wood wasp
  • 1 month later...
Putting my FMG Osa 250 on market next week, good working order and brand new crane control system fitted. Refurbed alternator, new filters and oils throughout machine. Also spares machine, runs and drives though some bits been removed like rear shafts, valve block. £10,000
Also got Lokomo 919 fitted with Kesla stroke processor, can be converted back to forwarder relatively easily, headboard and pins still here. Set chains front wheels 80% 12,000
For next couple weeks or so will be on site and can be seen working, after that they'll be in yard.
1000l ibc hydraulic oil 32, less than three months old. Sensible offers.
Located Central Scotland.
Will put on arbtrader and other places also as individual lots but thought grouping them here makes it easier to answer any questions.
PM or 07825 138865
Edit: I would put on arbtrader but app crashes when I try to upload image
Edited by Wood wasp
Spares machine fired up and ready for the low loader, sorry to see them going to be honest. I did have an idea about fully restoring the working machine but I just wouldn't have had time. ImageUploadedByArbtalk1437747369.972940.jpg.af0513588d7d0b15f4a75f0afdc25558.jpg
