I think they're great. 8x5 has a legal payload just shy of 2 ton, think about 3.5m3 capacity so you won't run overloaded... Fine to chip into, hard to fill to the brim though, i use the tailgates placed on top to make a little roof if i want to keep the mess down.
Just make sure you have something suitable to tow it, if you have a disco/defender etc you might aswell get a 3.5ton 10x6.
Sent from my iPad using Arbtalk mobile app
  • Replies 40
I have a ford ranger so what size will be best
We bought an Atlas with the mesh high sides.
We then cut the mesh out of the frames and pop-riveted alloy panels on to make a chip box.
We strap a groundsheet over the top when chipping to stop re-bounds and it can carry about 5m cube.
Regards
But that's 3500kg, and the ranger can only tow 3000? So down plate the trailer to stay legal?
I had an L200 so I went for a 2700kg 8x5.
You no longer have to downplate trailers, just keep them under the towing limit of the truck
The 10x5 and 12x6 ifor tippers are 3500kg? Don't think you can drag one behind a ford ranger legally?
Charlie.
thats the gross weight, ie how much they can weigh full. A 10 x 5 tipper empty weights a little over 1ton, meaning you can load about 2ton on it and be legal
