I'm thinking of trying an icicle hitch for a 11mm (ish) ‘spider’s leg’ balancer line back to my 16 mm lowering line for some medium limbs.
Its a one-off for me and probably not worth investing in a long spliced eye
Anyone have advice on suitable hitches for the application?
thanks
thanks guys
Sloth
I was trying to avoid connectors and other knots in the leg.
A prussic would mean adding a connection and a knot in the leg ( to connect to the connector). But it would'nt require any extra thought to perform it..which is always good
Paul
That's certainly less of a memory drain than tying and icicle hitch is for me. A klemhiest would also involve adding a connector and a knot..unless you just form a big open loop with a knot in the leg and tie the klemhiest with that?
What do you use?
cheers
Pete
Must say, I 'd like to go with Blake's hitch.
Do you find it holds ok for higher loads Mistahbenn?
I heard somewhere that its prone to slipping at higher loads..but maybe that's when tied on same section line
thanks
  • 3 years later...
just wondering about this myself - Mistahbenn or anyone - is the Blake's ok to hold a spiderleg (of say 2mm less dia than rigging line).
Also if you were to tie a large eye in end of intended spiderleg rope to enable tying the klemheist, what knot to tie the eye? (need to get splicing really)
