advise on a chain saw mill
roglog
thems windbraces,
ah kin tell from the brackets ah canny see on the ends.
Funny enough even though tubing is very strong, over any reasonable span it needs to be a considerable diameter to be stiff.
Folded sections are stiffer, in one plane anyway.
Ps
Wot weight?
Im thinking of purchasing a chainsaw mill for milling some pine to use for the roof in a pole barn im building this summer.
never had any experience or even seen one of these! any one recomend anything and are they simple to use, i think im looking to make 8x4 planks around 18' long idealy
been doing a bit of research into this and i think im going to look for a logosol m8 or norwood portamill. i would be interested in a second hand mill if anyone has one for sale.
hello rhob the log if u make that rail system on stands at each end how will u get the chainsaw mill on it without taking it to bits every time i thought about making one to do 6m oak beams for a garage i made but did them on a woodmizer in the end i made the rest with chainsaw mill
Edited by jacko 10
wrong name
thems windbraces,
Ps
Wot weight?
Weight? Dunno, haven't been to the gym in...11 years? No idea what I can benchpress now. Guess they're around 25Kg or so. Had a pic with my penknife for scale - 10cm diameter. You're right, they're windbraces. Leftover from the barn build. Seem mighty stiff to me. Turns out I won't need the length anymore...probably...still waiting on a cutting list. Cheers for that on folded sections though - might have a chat with the local steel fabricators see if they can point me in a lightweight direction.
No use building a frame at this stage for me, much easier to get the best starting face if you can rotate the log easily when chainmilling. Have seen a few redneck frames (on youtube), nothing as good as the flip n' rip Rob D's been touting though.
Interesting use of the ladder on that norwood. There are many types of mill about but finding a distributor in this country can be hard. Norwood's canadian, Logosol are Swedish. Let us know if you can find this kit new and best of luck finding a mill - sounds a good project.
