Setting up tree motion
Si_White
Welcome to the forum Si.
The treemotion needs to be set up so it feels like its almost falling off, which will seem odd at first. To start with put it on as normal, pull it down so that ideally the waist buckle should sit just beneath your belt time. To stop the harness from riding up your waist once in use, you then need to cinch up the keg loops and adjust the straps that attach from the leg loops to the back of the harness. Hope that makes sense
Ive also just bought myself a new treemotion-loving it but my nuts are getting a bit squished by the leg loops- not loving that. Any tips to get rid of nut squishing?
