Pole Hedge Trimmer
MTS TREES
I would go with the Stihl HT 101 Through HT 131. Depending on what size engine you need. The Stihl models would work well with either a saw or hedger attachement. The Echo Power Pruner is only available with a saw since nearly 3 years ago Echo dropped the hedger attachement for the Power Pruner. Good Hunting.
easy-lift guy
easy-lift guy
The hedge cutter attachment is still available this side of the pond.
Echo - Echo HCAA2402 Hedge Cutter | Long Reach Pole Pruners - Buy online from HobUK
It is a bit heavy shame someone could not invent some sort of harness to support it :thumbup:.
