Made it just now using a fix cheek pulley and a mallion rapide, fix cheek rated at 12 kn and mallion rapide at 1750kg swl. Bit of New England hi vi, Marlow boa cord and a bit of innertube to protect the cord from the pulley. Mallion is that way up so it can be retrieved in cambium saver mode but not retrievable when chokered.
Just making sure it is ok to suspend my whole weight on the isc fixed cheek when chockerd ( rated at 12kn I.e 1200kg) as I've only seen pulley savers with pinto pulleys?
Thanks Arran
Sent using Arbtalk Mobile App
  • Replies 77
Side loading on the mallion isn't problem because of its high swl
Yep,that part wouldnt worry me,as long as its pinched up.:001_smile:
Is this combined tree services/tuttle making a comeback bid? :lol:
Not unless he's got Arran bound and gagged. I can verify Arran's existence as a separate entity to tuttle:001_tt2:
Yeah, it doesn't look an ideal match to me, like Geoff said. It would be better to have something between them like a mallion. I used to use a ring to ring saver with a pulley and mallion attached to the little ring, worked a treat but wasn't adjustable length.
