Sealey SM21 tank cleaner?
AlvinD
I got a Safety-Clean, Solvent Parts Washing, Parts Washers, Parts Washing Services | Safetykleen UK had it 15+ years and still got the same fluid in it! ok it hasnt been used for the last 8 years it was in the corner having a rest:biggrin:
So I decided to get at it and use it again, expecting the fluid to be long gone with just sludge in the bottom of the drum, I was amazed to seen a few gallons still in the drum. Then thought if I switch it on maybe the pump will get knackered before I can turn it off.
So took the pump out to make sure it was clean first, even the fluid was clean so put it back together and switched on, bingo.
Working as good as the last day it was used years ago, I put this down to making sure I changed the filter when it needed it and that paid off.
Its a great machine with a built in light on a flexible arm, I could get the fluid changed years ago I had a mate in a garage who used them but now I think I will be using white spirits when it needs topping up:sneaky2:
I seen one on ebay a few months back but cant remember what it went for, they are much better made than the DIY machines but were never made for the DIY market, they were on lease as far as I know.
