Did you get the right length . If they were too long they could bottom out befor they clamped ??
Or too short.....:thumbdown: I keep some very high temp bearing lock for this sort of thing - funny, I usually find these bolts are rock solid after a bit of use!
Saw back up and running.new piston fitted by blackwood chainsaw no damage to the pot £120. They said castrol 2 stroke oil is no good in an XP saw ??
Not a bad price - hope they did the right checks on the saw and tached it?
Hope it works out for you - they are decent pro saws and cut fast when set up right.
Saw back up and running.new piston fitted by blackwood chainsaw no damage to the pot £120. They said castrol 2 stroke oil is no good in an XP saw 😐??
I would be suspicous of this? Did you pay the £120 or was it done under the warranty.
