Picus testing
danroker1987
It's a useful tool sometimes, as long as you know what you are hoping to achieve and what the limitations are.
You only know whether it's accurate when you fell the tree and compare the stump cross-section with the scan image!
meaning that the wood could be more dense rather than it looking soft on the scan? if that makes sense....:thumbup1:
As Paul says, it is a tool (albeit a very useful one...and a tad expensive) NOT a tree inspector and not an excuse for not doing a full and thorough VTA.
IMHO oftne used to confirm one's suspicions anyway but can be very useful in tree retention scenarios, i.e. where you're just not sure and the temptation is to remove JIC!:confused1:
Cheers..
Paul
It's not great at detecting decay caused by Kretzchmaria deusta - i.e. tree could be more decayed that the scan shows.
PICUS is often requested unnecessarily too. It's only useful for evaluating butt/stem decays, so there's no point in using it when you have a root rot present.
We were asked to do a load of PICUS scans on street trees last year. I went and looked at the list of about 20 odd trees but it was only worth scanning a couple of them. How many street trees do you know that fail at the stem? Most go over because of root problems - a PICUS won't help predict that.
Have you got a particular tree/situation in mind that prompted the question?
Does anyone ever get picus tests done,?? is it accurate?
Yes:001_smile: No:cursing:
Should give a bit more detail, it can be a useful tool but can also be a complete waste of time. Sometimes will need to be used with other methods to back up suspicions.
Not always the gods gift to tree analysis.
Edited by treebloke
