  • Replies 26
The issue with this is that while it's fine for a screwdriver which you holster everytime, the only thing you can do with a saw is drop it and leave it hanging, there's no close ring to clip onto a caritool, so every time you drop the saw it's off down to 1.2m away from you and all you have to haul it back up with is 1 point something mm thick coated wire rope, which ain't exactly 'nice in the hand'.
What it won't do is retract and pull a 5kg chainsaw back up to your harness!
I'll be sticking with my 2 ring bungee strop I reckon....
True but I use a large caritool and clip the handle of the saw to it so its nice and close and doesn't swing about
Good point :thumbup1: don't you find the bar jabs in your leg/arse/anything else though... ?:001_huh::biggrin:
No not really I clip it to my left side and onto the left hand handle so it sits pretty level and the bar points away from me
no, i use a 3mm metal clip i found on a building site that i bent into shape (a lot smaller that a caritool), mount the chainsaw to ya harness one handed and no more bouncy saw
