i have just done 3 stumps with my mk1 and is great for the price , but managed to find a buried steel bar :( . Are there any other teeth that fit or is it best to stick with rock machinery teeth?
do yourself a favour and change it to greenteeth if the disc won't take them get it modified to take them its a far cheaper system to run
They don't fit, I checked! The holes are 25mm apart and greenteeth are 40mm
so if there is no alternative teeth, that just bolt on , think i am going to stick to rock teeth. Dont want to change the wheel untill grinder has paid for itself and paid me some profit.
Nope any change needs a new wheel, can't remember the exact figures but multitip was around £500+ vat. By the time you pay that kind of money to switch it takes a fair few teeth to make up the difference in comparison with just sticking with the original ones. Best bet is get a cordless grinder and a diamond disc and keep them touched up
redrill the wheel to take them the green teeth are 38mm centres with 17mm holes its relatively simple to do worse case you have to remove the wheel to do it
You wouldn't have the space, the current holes are 10mm and there's not masses of room left over for a bigger hole, plus the wheel is in two halves, and then you'd have to factor in the spacing to not hit off centre existing holes to leave them too big, if that all makes sense!
Ideal you'd just get another wheel made, God knows what that would cost to be made bespoke!
  • 8 months later...
