Ms 310 service.?
Ready84
In addition to Riches list, check the sprocket/rim for wear and replace if required, check recoil rope and recoil action, lube needle bearing on the sprocket, make sure the chain isnt spinning on idle.
It is worth checking the gauze filter in the carb pumping section, crap does gather there over a year or twos use!
Check the condition of th echain catcher and chain brake - clean the mechanism and check for correct operation.
Give the whole thing a good clean out!
