Crafty fox needs to die
treesnatcher
An old chap told me to chuck the trap in a pond overnight to erradicate smell on it. Guess This would work, I wouldnt keep my birds behind anything but chainlink, 6ft high with a 1ft chicken wire protrusion at top. See loads of fox prints in the snow round the run, but they never get in. Touching wood right now!
If you are very susceptible to fox attack in a rural location you need to build your chicken run like a pheasant pen.Firstly the wire must be a bit poor if a fox can chew through it.
Run your wire down to the ground then run it out flat to the ground and flat out about a foot.Peg it down.
Burying it straight down will just result in the fox going up to the fence then digging down and under.They dont have the intelect to back off a foot then dig.
Run an electric fence wire around the pen eight inches of the ground run off a good fencer and car battery.Cheap to run and effective.
Hope this helps.
Cheers.
Andy.
Also, i should have said.Foxes can climb weldmesh.Use plastic mesh on the upper part of your fence as its springy.A persistent fox cant throw itself at it and climb up.Leave it `flappy` at the top,higher than the posts.
I`ve built several pheasant pens and have never seen fox penetration while the poults are in using this method.
