Hitch climber / skywalker and best solution for base anchor...
WorcsWuss
2 things....
I'm making up a new lanyard (as discussed elsewhere... ) and I think I've settled on 5m of 10mm OP with 8mm Sirius or similar... For now I'm going to hold off on a cinch.
Any who, I dislike clutter, particularly on my bridge, so rather than a micro pulley like I have on my other strops, I'd like to use an hc or skywalker so I only have one krab on my bridge.
I like my hc but it seems a bit over the top for a strop and quite bulky, so I'm thinking of trying a skywalker.
Does anyone have both and could you post a photo of them together so can get an idea of any difference in size? I'm hoping the stein pulley is smaller.....
Second....best solution for base anchor? I tend to use plain ended cut lengths of rope for everything, but I'd prefer something a bit more purpose made to attach my new static rope to the bottom of the tree.
The cheap and cheerful solution is a length of 16mm bull rope..... What's better....?
out of curiosity do you use your strop on your d' s or bridge as a secondary rope...?
i use spiderjack on main line and 5m rope and prussic... hate prussic binding! thats why i went to spiderjack on main line.
i have a hitch knocking about and wonder if its safe / you can make a rope out of it so to speak run the hc and 8mm friction cord... would either want 5 or 8m rope...hmmm
Both Chris, depends what I'm doing. Both my current strops have vt's on them, one is 9mm boa, super long one which i also use as a second line now has 8mm OP, both on isc micro pulleys. I make strops up regularly out of odds and ends I find lying around.....! :biggrin:
The skywalker is almost the same size as the hitchclimber
Cheers Paul, I might give one a go...:thumbup1:
