just like a SJ or LJ like steve said feed it in from the other end of the rope
steve as ur a man in the no have u had a go with the zig zag
no. I did see one set up and had a play when i was in baltimore, not climbed on one though.
oh i wanted that not to be the case !!!
never mind i guess by the time you have your climbing line in place there will not be so much to pull through, both ends spliced will take a hammering !!:001_tongue:
tar lads
take a look at the rock exotica unicender which can be attached midline. Cutting edge man at apf was saying they are having probs with premature wear at the mo so is being redesigned. Looks very nice though.
A LJ can be taken on and off mid-line by removing the clutch, it's just one long screw that holds it in place :001_cool:
