On 1/14/2018 at 12:01, ABtrees said:
Morning just going through a few old photos and came across this one of a large fruiting body I found - thought it might be of interest (?).  I was given the trunk of a big old oak that had fallen over about 10 yrs previously and been laying in a ditch ever since.  It was wet through so decided to split it let it dry.  On the second split I found this - sorry there is no scale reference in the picture but the ring was about 1.2 m and the corner of the splitter (bottom right in 1st photo) is about 10-12 cm.  In my (total) ignorance, just wrote it off as being a bit of dry/wet rot, but it was the fact it was right in the centre of the tree and the structure of it that prompted me to take the photo.
Possibly the mycelial felt of a long term Laetiporus sulphureus colonisation.
Reminds me - on one of our projects , have a three large multi-stem willows to kill on the side of a wetland habitat . Basically want to reduce the water loss to the pond in summer. No chemical herbicide should be used realy - so think I will get them felled then introduce fungal matter in the cut stumps and cap them off to let Nature do its thing . Has this been done before ?? K
I've not done that, normally just let nature do its thing or give it a little hand by ring barking just above ground level with a saw. I haven't read anything specifically about inoculating stumps to kill them, (Paul Stamets, in his book Mycelium Running) talks about inoculating with saprotrophs to combat pathogenic species) It may be worth introducing the stumps with a strong parasite like Armillaria mellea. Not sure of the best way to do that but perhaps see if there are any commercial plugs available and drill the wood by the cambium (like the glyphosate Eco plugs) . I've seen mycelial plugs of other Armillaria species available, but they're more saprophytic in nature and are unlikely to kill a 'live' stump.
Will ring bark one pole out of the multiple, for a perch,  then cut lids on other stumps n bore out centers. Handful of Fistula or Amillaria in each and see how it progresses. If it ain't been written up before  will detail it and progression of decay. K
You see that's why I joined this site - I really have no idea what you guys are talking about - but you get me thinking !  Before I read your post Khriss I would never have even considered that the fungi may have taken because the tree was actually in the ditch and therefore been instrumental in its failure. In my ignorance I assumed tree got blown over fungi invaded as a result of it being waterlogged for a number of years etc etc.  And David IF I understand it correctly this is just a remnant from the visible fungus that would have been present whilst the tree was standing ?  Back into the woods next weekend then to find some 'chicken' - right time of year ???
Thanks both.
Fistulina might be a waste of time,   It's slowly pathogenic ( although on trees with high tannin content) and I not sure, but I don't think it's commitment may found on willow.
Indeed ABTREES it's a whole "World of Stuff n Things" on here ;) an Gary, I will trial three of the fungi on each tree an as it's an 8 yr program of works we can see how it turns out- my money is on Amillaria but will put some laetiporous in too, k
Thinking about this, would you be better substituting Ganoderma for Fistulina?
It it would be interesting to see which of the three prevent/reduce regrowth and decay the stems quickest. Might be better to leave an inoculated ‘control’ as well for comparison.
Perhaps better with Laetiporus than Fistulina,
Armillaria definitely good
