""Touching trees" (getting 'up' close & personal) is the only way to 'learn' what's going on upstairs. "
True, but i was also being more literal than that, per the detective's hands-on work below:
I felt the slightly shriveled and
sunken bark above the question mark and
tapped and pried off loose, dead bark.
The woundwood felt thick and hard under
my fingertips, the richest source of tactile
feedback on the body. Mechanoreceptors,
packed under the ridges that form my fingertips,
felt many years’ worth of growth in
the texture of the lignified callus.
  • Replies 65
Clearly you have been privilaged with oportunity to make most operators look lazy.
Very nice work David
Jealous
Jonny
Privilaged?
Not sure if that's quite what it is.
I could just choose to steer our management to just cutting em down and making the place sanitised and über safe.
Would make my bosses sleep easier at night.
That's what we 'used' to do 15/20 years ago.
I/we've spent a lot of cpd time at conferences (during and outside of work in our own time) not to mention budget in pushing our knowledge and experience along.
It makes the job far more 'interesting' for sure. :thumbup1:
I much prefer the cut and thrust of properly (sensibly) evaluating a tree for retention.
As you say it makes it more interesting, especialy when initial investigation via binoculars points to an aerial defect and actualy seeing what is going on when you get up there
Hi all,
Just on the subject of 'aerial tree inspections', the AA Arborist Working Group ('AWG') are currently working on a guidance note to assist undertaking these where there is no clear instruction as to what the client/owner/consultant wants checking, i.e. a general instruction to undertake a climbing inspection of a tree.
I'll let you know when it's published / available.
Cheers all..
Paul
Fantastic news Paul.
With there currently being no realistic qualification that covers aerial inspection to any great extent, I've just been out and bought my own new climbing kit in order to undertake them myself, as I can't cover the liability by using our contractors.
They will be accompanying me on the climbs in order to cover lone working and aerial rescue aspects of the climb etc, but the inspection/decision making/analysis etc will be carried out by me.
Picked up a flexible shaft drain camera earlier this year, for doing internal inspections of cavities. Great bit of kit that'll let me take photo and vids for inclusion into reports and/or survey records.
I know that bit itself doesn't exactly relate to aerial inspections, but I did get it with a 10m extension - which I can send up to a clmber to poke into a hole, why I stand below directing and recording.
Sent from my BlackBerry 9700 using Tapatalk
