Hi desired
is there an easy formular
no sorry
have a try at the rigging resurch and see how you get on
in terms of kn in to kg for what you need
if it says 25 kn take the 25 replace the K with a 0 and the N wit ha 0 you get 25 00 =about 2500kg.
as for the phisics the further you drop it the shorter you stop it the less rope in a sysytem the stiffer the tree the center of gravity the drag of the canopy, the stability of the tree and its species, the kit you are using, the terminations in it all play a role
keep the distance of fall small the logs small too
cheers
  • Replies 20
