  • Replies 30
Have you thought of our new sawhorse!
Main point is it holds all the wood so no more bending down and having to pick it all up!
I like the fact that the cups hold the cut stuff too.
How long does that beam under the cups last and how do the cups fix to its replacement?! The beam's life would be extended if each cup was on a separate block so there was clear air below your last cut.
You need raised cups!:blushing:
Edited by Steve Bullman
Cheers nepia !e have a new design coming in June that the cup height is a lot more but to be honest the beam is sacrificial. The trestle is ajustable so that the height is set so you do not have to bend and just let the saw do the work. We one we use to cut our logs and its 8 months old and the top beam is still good.
Also Woodworks you can get bent stuff in the system the cord holds the wood in and you just cut! The big thing is that the wood falls into the cups and once you have finished cutting and creating the logs. No bending over you just tip the hinged cups so you pile all your wood into your bag, barrow or truck!
It's not fully loaded but check this out to see how fast you can create logs
Hi Yeti this can hold pretty big logs have a look at the vid I just posted on this thread.
We are developing a device that holds all the logs ready to cut and then puts the logs into log bags with out any bending or having to hand fill them!
Cheers Nepia we should have a demo unit down in West Sussex in the next month At Deers leap when it's there I'll post if your down that way you can have a look.
