  • Replies 37
some cracking kit on here guys !!! it just goes to show that tommer and myself are at the small end of the scale !!! never the less were loving using the chipper and crane . i for sure would love to get a bigger machine but cant see there is much call for it in cornwall
A roof mount is the most versatile but you will need a PTO pump for the crane as it'll run so slow otherwise. Slow but usable.
As with most things in arb, it's trying to find the best compromise!
Except this won't be in arb; no bloated crane required :001_tt2::biggrin:
Really really don't want a pto pump - no good anyway with pto chipper.
I ran a Valtra 8950 with roof mounted Foresteri and 3pt linkage pto Heizohack 5-400(16")..
My thoughts;
Good visibilty with roof mounted crane but..
Jake frame mounted cranes much more stable and you can get support legs
Would recomend Kronos crane(I now work for AC Price and the difference in usablity is considerable)
Versatlity- could forward when not chipping
wheel weights, front weights and ballasted tyres help stability
We crane fed a TP250 first then went to heizhack, disc chippers suffer when blades are blunt whereas heizo will still chip
We went 3pt linkage due to access on jobs(railway)- trailer type heizo can handle bigger stuff but restricts off raod capablity
Stan
Have used and abused various set ups and you get what you pay for in terms of crane quality/speed, crane controls, chipper build (crane bashing survivability) and blade usage..
