Has anyone tried filling their rayburn with wood chip?
I was thinking of chipping some clean, seasoned, small diameter hardwood and fill the coal scuttle up to try it, I figure it should bun slowly as their is little air gaps. Is their any reason why this would prove stupid, or dangerous?
i,ve tried it in my coalbrook severn no probbs at all but only when its running hot just loads of mess etc i would say bag it first lobit it on n shut door all done no mess
I tried it in an old burner we had, It worked well mostly then a couple of times I was sat with door open on a freezing frosty night sweating in my underwear as the got carried away and refused to calm down.
I have burnt some in our woodburner, bearing in mind this was chip I had dried in the oven (to check moisture content) sometimes it burns from the outside like a log, but sometimes it gets hot inside and smoulders which must be less efficient and probably would soot up the flue eventually
