................They are lovely brackets, the manufacturer of those needs naming, or pm me if not allowed.
A
Oops, thought I had included a link earlier.
Guys name is Simone Aresu who's an artist and metal worker based in Newmarket, Suffolk.
Steel Work
  • Replies 34
Normally fireproof board on the inside edge only. If its very near then put an air gap between the board and the beam using spacers at each end. You cant put it underneath as it would look dreadful. Available from decent builders merchants.
In this case the wall that the beam is mounted on is sufficient IMHO, but the person signing it off as safe to use has the final word. The clearance underneath simply needs to be in excess of the stove manufactures recommendations in their installation manual. If there is no recommendation contact the stove seller or the manufacturer/importer themselves. From personal experience I would recommend going at least 25mm higher that the manufacturers minimum.
A
Cheers, should have been clearer with what I meant. I have a Rayburn in the kitchen that has units near it and I want to add some type of fire protection to the side of the units. For this what would you recommend?
Thanks
Jay
