There was a glow worm gas fired back boiler fitted. The roof had a stack which stood 2 feet above the ridge. Seems odd as other houses all have different pipe even though they are the same age and style! I think I will get someone in to look as Im no expert! Definitely looks to be the same construction as far up as I can see and from loft it looks the same. Would be perfect if it was suitable. How do you sweep them? Do you need an access hole?
  • Replies 22
Usually stoves are swept by removing the firebricks and the plate that sits on top of them then swept through the stove. The alternative is a door in the flue pipe above the stove but gaskits tend to fail after a couple of sweeps so have a spare if you go that way,
I would get a local guy in, either an experienced HETAS engineer or the building inspector.
Just noticed you are in Scotland, the building regs I am talking about apply in England, not sure if they apply up with you but I would think so.
A
