Well, good sized ones anyway.
If anyone ends up doing a removal of a decent sized plum (type not important) please could you bear me in mind. Anything over 8" dia and 4' length (although 6'+ would be better). I travel around quite a lot of the country from time to time so location shouldn't be too much of a problem.
Our bedrooms are all in the eaves, so no furniture fits and I'm going to have to make it. I'd like to use plum as it would be a good contrast to the elm floorboards.
Cheers
Alec
To clarify - 'type not important' means things like blackthorn, damson, cherry-plum (prunus cerasifera), even prunus pissardi are all fine, as well as the more conventional plums.
If anything shows up over the winter months please think of me!
Cheers
Alec
I felled a lot last year last year doing a garden clearance job. Got some small cherry plums to do soon on a job the only problem is a firewood man is ment to take all the wood but will ask land owner if any big enough for what you want will PM you to let you know.
Thanks, much appreciated!
Alec
