What is it with today's motorists?
Driving back up the M11 from work this evening, and its a little foggy.
But a good 150 yards visibility, and every other moron has their fog lights on!!
So you are following cars with this intense red light right in your eyes, so when they actually brake, there is no distinction between the two lights.
When do you use your rear fog lights ??
I use mine when it's thick fog, until a car comes up behind me then I turn them off, same if I overtake a car I turn them off till I can't see it's headlights anymore. Otherwise they're dazzling
Rob
when theres nowt behind you so you can been seen in the distance before someone runs up your ass. soons somone is behind you switch em off. sodding things are blinding. I normally feel like giving em full beam see how they like it!
when idiots are behind me in there crappy little cars with their front fogies on.
but then the big bright light on my dash starts to annoy me so i turn it off, and just turn the rear view mirror down
For one contract I had the rear fog lights wired up to flash along with the ambers and reversing lights. The van wasn't sign written. Used to produce some interesting results if you just turned them on when some pillock got a bit to close behind you.
And no I haven't got them anymore - fortunately or is that unfortunately.....
Turn on my rear reds that gets them to drop back quickly ;)
Or if there is front give them a blast of the front ambers and headlights, makes for some intersting reactions.
