  • Replies 24
Any stove over 5kw needs an air brick as per part J building regs.
ย
You only actually need an airvent if you live in a modern hermetically sealed house. If you've any concerns buy a carbon monoxide alarm.
ย
For a big boiler stove I'd recommend an Aarow Stratford TF70 or TF90, I wouldn't fancy taking a gamble on a no-name stove at that kind of money!
ย
ย
air vent still needed in an older property when the stove is over 5kw
but the calculation is for every KW over 5 kw to work out the air vent size and carbon monoxide alarm is part of the building regs so has to be fitted to be able to sign the stove off
ย
Yes, I know, but the building regs are a 'one size fits all' nonsense. The reality is that you don't need a vent if the property is already well ventilated.
ย
What exactly do you mean by 'signing off'?
  • ย
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. ย
If you're just starting out and you need business, equipment, tech or training support you're in the right place. ย If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,ย ย then you're welcome too.
ร—
ร—
