Slack tending a hitch climber? (not the obvious way)
YoGi_93
secret weapon with a melting point of "Dyneema® fiber has a melting point between 144ºC and. 152ºC. " ??. i know your a fan of dyneema bro but i just dont like it being used where heat can build up. But im sure yours is sweet as... Whats the advantage in using dyneema in that application? not having a go, just curious thats all.. is it because its small?
just googled it- its covered yeah? :)
Edited by DrewB
google
yes its covered in grippy polyester, its only used as a fixed prussic or temp cambium saver, stays on my lanyard.
it is great stuff for the right application, i did splice my pinto with it too.
I'm currently using a random piece of friction cord, 6mm diameter. Yes it works fine but I was looking for a quicker option than re tieing a wee prussik everytime, Yes I know, how lazy? It only takes seconds, I know. But the tibloc would be quicker. With the "O" rig I thought it wouldn't be taking that much weight, just enough to slide the Bulldog up. What are folks thoughts on that????
The other option I was playing with was a Kong duck, but £40!!!
Bing!
Looks like I will be sticking with a prussik then. Or maybe a modified cam cleat, Hmmm, more tinkering on the horizon.
Surveyor, how far do you get from your house before you have to head back to try out another idea???? I have visions of you either in the workshop or hanging from a gadget in a tree, does your family get to see you? :001_smile:
Bing!
