I've found that one of the easiest things to make and sell are rustic picnic benches.... the reason I think is everyone usually has space for them, they can be competitive with manufactured furniture and you have a built in table and seats.
If you make a table with separate benches it takes longer and is not so practical as the benches are too heavy to move in and out.
The mini mill with a 15" bar and cross cut chain flies through the wood and can be used to rip down planks. It makes it a pleasure to use... or more pleasurable anyways!
The vid isn't that good but basically:
  • Get the top flat
  • Mill a 3" board and place to one side
  • Using the mini mill cut across the log at bottom, 27"-28" up, another 27" to 28" up and then 6' from there
  • Mill a 3" plank and you bow have 2x 28" pieces (legs) and top (6')
  • The legs are squared and at 3" sit nicely on the 6' piece
  • Cut the first board you made down the center for seats and use the end of braces
  • Put together and leave for 2 to 3 months
  • Now the wood has surface dried spend an hour planing and sanding just to smarten it up
I sold x4 of these at a show for between £360-00 and £440-00 and you can make massive versions.... an upright support needs to go under the seat though or x2 big 'uns on one side will have it over!
[ame=http://www.youtube.com/watch?v=-FM7Y8gVOaw&feature=channel&list=UL]Log to bench - YouTube[/ame]
And I made this one at home from planks off the same tree. Plan is to make a boatload of these now ready for a sand and tidy at the beginning of the next garden season.
very smart! Wouldn't the bark fall off fairly quickly?
Yep in hot weather the bark would fall off pretty fast - this is a benefit really as you need to be able to get in and sand it.... I leave until the bark falls off and the table's outside is dry and spend and hour sanding and planing.... It looks more 'finished' then and is ready to sell.
Rob you were mentioned in the eastern daily press yesterday, there was a Mrs Green looking for her two walnuts to be taken down for free by the sounds of it and the gardening expert said you would be interested!
Ha ha! Really? I may be interested if they were big enough/good colour but they'd have to be special to get my old truck and trailer that far afield!
:biggrin:
