Oxtrac rating?
Good enough to buy one!
Good on soft and steep weak spot is rocky or tight stumps / ploughed style plantations.
Once you get used to the stick drive control is easy.
Track maintenance is a pain but the ground damage is low. I've skidded 75-100 ton out over pitsteads and after a superficial tidy up you wouldn't know we were there.
If you're in Cumbria come have a play or go to the demos by Cumbria woodlands - you'll only be able to watch but better than nowt.
