Fit a super simple light weight hiab I would , one that lifts with a manual pump as they will lift 6/7 hundred kg no problem and just shuffle the bag when it's on , weight saving is the key with a light pickup
don't really know alot about them,that one on the Navarro does it just bolt onto the bed and run of the battery or something ?
they can run off a power pack i have the next size up fitted on my Mog running direct of the hydraulics
the crane either has 4 bolts to hold it to the vehicle or some had a framework that again is bolted to the vehicle
A swing crane is light weight and easy to use. Think you can get a decent one on eBay for £150. Uses an electric winch to lift and man power to slew.
My palfinger hiab on my lt35 weighs in at 2.2t unladen....
I have a small swing lift on my ifor. Lifts builders bags full of logs and chip as well as dragging them out from the barn. [ATTACH]98390[/ATTACH][ATTACH]98391[/ATTACH]
i have seen swing cranes for no money at all on line but what sort of weights can they lift ? iv never weighed a bag of chips or logs ! i know it depends on moisture but what do they weigh ?
