I would like to introduce yet another new model to compliment the Bandit range of stump grinders, this is called the 2550XP and brings the range up to Fifteen different models. This machine is developed with the same technology as the 2250xp using a hydrostatic motor to drive the cutterwheel eliminating all belts, bearings, clutch, tensioning system and jackshaft. The cutterwheel is put into gear via one simple lever.
Powered by a 45hp Kubota turbo diesel engine this model has stacks of grunt and with a 50” swing arc, there is less need to keep re-positioning. Std fitments are Greenteeth, swing out operators station, debris curtains, hour meter & dual wheels.
Other options available are:
• 4WD
• In built hydraulic pressure check system
• Radio remote
• Hydraulic grading blade
• Sandvik cutterwheel
• Six optional colours to choose from at no extra cost or your own company colours
Regards,
Dean Embling
Sales Consultant
Global Recycling Solutions Limited
Cook House, Brunel Drive, Newark, Notts. NG24 2FB
Mob: + 44 (0) 7730 000498
Welcome to Global Recycling
Hello,
I have an HB20 Sidewinder powered by the same 27hp Kohler as the 2250XP
The 2250Xp has far larger wheel with double the teeth (at least 16?)
How does that translate in terms of performance against the 8 teeth of the HB20?
Also, how do you drive such a machine if the controls are on the side?
I imagine narrow passages and gateways must be...interesting...
Ty
Stuart just to clarify, the picture attached is the 2550xp (45hp) so ignore the swing out station as this is not applicable on the 2250xp.
Regarding the the difference, the cutterwheel on the 2250xp is 20" x 1" thick instead of 14" x 3/8 thick on the HB20. This means the wheel has alot more momentum when grinding enabling production.
All Bandit grinders except the 2250xp are available with radio remote & tether control so you do not need to stand at the side of the machine, it is not available on the 2250xp as this is built with budget in mind.
The grinder is not a narrow access machine at 35" although there is now an option for approx £350 extra.
  • 1 month later...
Still saving...:001_rolleyes:
Thing is, I have rarely lost a job due to the size of the HB20 BUT...
It would be nice to work less hard and to be able to bid on some serious contracts.
Bit of a step up eh?
Ty
