  • Replies 35
Do portek discs fit? Didn't see spare ones in lidls!
Not sure mate, I own neither.
I think the Lidl is a rebranded 'Grizzly' whereas the Portek is a err.. Portek.
Might all be the same thing from the same factory, but I know Portek do a 'better' version which is what I'd buy if I ever take the plunge. Disks for these are readily available from Axminster Tool.
How does this unit compare to the Portek ones?
There both cheap but the portek one costs 6 times more. I have had a lidls one for a couple of years. I bought 2 so I could chuck it when the disk wore out if could not find a replacement easily ( how lazy is that but time is money) you probably won't get through many disks unless you are wrecking 4 ft chains. I hand sharpen but use the grinder after about 6 tickles if my sharpening is un even one side or if I hit debis in the timber. Using it every sharpen I think you will half the life of your chains.
