Jo Beau m300 blade bolts
Andy Collins
Trying to order the correct size bolts for my m300, absolutely shedloads of bolts described by measurements only, what do I need? :confused1:.com :001_rolleyes:
You need to go to a shop that sells bolts bearing a example of said required bolt.
OR look online for a thread gauge,then measure the threads on you bolts,the diameter of the bolt,then the length.
The tensile of the bolt might be stamped on the top.
Thats right, slightly rounded take a 17mm socket, or whatever stupid size the local village idiots gunned it up with :001_rolleyes: hence the beginning of the problem. Actually havent managed to get out the most damaged bolt yet, looks like a rats chewed on it. Pillocks.
