Is there a rate for splitting a cubic bag of logs
The guy i have just started splitting logs for thinks it would be a good idea to charge per bag i was thinking of £10 per bag what do you think?
  • Replies 21
How are you splitting? If it's by hand, you run the risk of a crap day's pay if he puts a load of knotty old crap your way. I only ever work for a day rate when splitting logs for other people, it's much safer. :001_smile:
A palax combi doing 4-5 bags per hour on small stuff , so when i get into the good going i should manage 5-6 cube per hour
Just wondering if this was a good price as i have around 300 tonnes to do for him
It is my machine and tractor the estate supplies two men to feed and change bags and an extra £80 for the day if i put extra splitter on the front for them to use will i cut at the back
Is it a full cubic mtr bag or a builders bag at half a cube. I normally charge per day as it is less risk but if they insist on price per builders bag then I normally charge £10 a bag for only half a cube. I would certainly not be putting 5-6 cube an hour through my Palax Combi as I value my back. Maybe ok for the first couple of hours but you will certainly know about it after processing 300 tonnes.
john they are full cubes , the lads on the estate are passing the timber to me
i have been using a palax for the last 20 yrs or so , so really it is just a breeze in the park
