Local flooding
Matthew Arnold
My local river in the past 24 hours has risen about 6 ft. It is still rising and its crown lifting the trees on the river banks so it can flow easier. Several trunk roads in the west of the county are closed as are the local minor roads. One of the villages has been blocked off by the flood water which is at its highest since 1979 when it breached the flood barriers.
This is the road from Sturminster Marshall to White Mill (between Wimborne Minster and Blandford for 'furriners') at about 08:00 this morning. This flood is about 1/2 mile long and at its deepest it was about 2'6" and the current is strong. Perhaps more worrying I had to stop and turn back the driver of a van (Escort van sized thing) who was about to attempt to drive through it, what are these people on! It is amply deep enough to float a vehicle of that size.
The water is once again flowing through the ground floor of the mill. I can only remember it being this high about twice since I moved to the area in '87, and never in July!
Reported this tree to the local EA. Although it doesn't look like it is causing problems to the bridge the "splitter" parapets are only designed to split water and not to hold large trees. They wont touch it until the river drops below the height of the bank. Whats scary is the channel it came down is a man made channel when there used to be a mill there and it normally dry during the summer. Most trees flow as a vast rate of knots and get snapped on the main bridge butresses.
