088 sound "odd"?
mikecotterill
Hi guys I put a post up about this a while ago at the time I thought the saw sounded odd, the advice given was to put a new decomp valve in which I did. I used it again at the weekend and there's a new noise now. It only does it when you lever the saw into the wood while cutting and sounds like there's a nail in the wood constantly. Any ideas? I've not checked yet but wondered if it could be the nose sprocket? Cheers people
Could as said also be the sprocket (needle) bearing - the one the drive sprocket runs on.
I had almost exactly the same thing a few weeks ago - looked at the needle bearing and it looked fine - changed it and the noise went.... worth investigating.
:001_smile:
