Hi all just started getting problems with my processor, its a hakki pilke oh 60,
when cutting it starts losing power! will cut smaller wood but slows down to stop on bigger stuff! Its not belts slipping it just looses power! any ideas out there? cheers simon:confused1:
I've an OH 60, hows yours driven and how close is the dealer you got it from? I had similar trouble if I used my little tractor on the 1000 pto at low revs, not enough grunt. What state are the teeth in? just had mine re-tipped and makes a big difference.
it may need a shrapen,they dont last for ever:001_smile:
will give it a go! pto driven off my international 674, closest is halse about 40 miles away, sharpen 1st then see! cheers
is it hardend or a normal blade,harden needs doing on a machine, u can do others byhand but u need to know how to do it
The tractor should have enough poke, it sounds like teeth. I'm assuming that you're not hearing any screeching from the belts until the blade stops and that its been fixed to the shaft securely. give it a sharpen and don't let the big pieces lean on the blade too heavily - I get mine to slow right down if I rush bigger Oak pieces.:001_smile:
Check fuel filters on tractor and make sure the pto clutch pack is not slipping. If the belts arent slipping cant be much else. Does the tractor smoke under load. Are you running small tractor on 1000 pto at low revs.
