Just been looking at tractors this morning
A new t171 or a second hand t191 similar in price and power output both hitech models , to run a heizohack chipper
Does anybody have any good or bad experiences of them
speak to arbwork on here
he has a t190 with a heizojack....
how do you rate the kelsa to a botex:001_smile:
Who me? Not much experience of botex, except for taking my assessments on a scrounged one! I think brushcutter on here possibly has more lever time to compare cheers J
the kelsa seems to have better reach:thumbup1:
I have more time on a Botex than a Kelsa. Used both the bigger Kelsa harvester/forwarder cranes and their tractor/trailer cranes. They're both fantastic cranes just do different things.
I've never used a 3 series Botex only the 5 series (560TL etc). They do them in 6,7 and now 8m reach (i have a 7). To go with this they have a massive lift capacity plated at 2.8t close in! If your doing big hardwood sawlogs then a Botex will more than likely be the crane for you.
The Kelsa are a little quicker in general use but only have a lift capacity around the 1.5t mark close in. The extensions are generally quite speedy even on the jake mount off a valtra 900s tank.
I have yet to see a Botex piped up on fancy electrohydraulic though to run through the joysticks on the armrests. Where as Kelsa do this which makes a massive difference.
Comes down to Botex=power Kelsa=reach & speed.
As Jerry said Power=chips just make sure you s/h T190 isn't used and abused. The only T series Valtra i've used is a T130 and it had a engine problem.
Just been trawling the farm forum , it seems that the high power valtras seem to be getting a bad rep at the moment
Bad brakes and pto packs
Anyone heard anything ?
Only hurd of a broken engine on a T130. Had the PTO clutch go on an A92.
