262 clutch needle bearing
Logrover
copy and pasted info for other saws using same bearing. Oregon brand $6
Drive Sprocket Bearing for Husqvarna Chainsaws 40, 45, 49, 50, 51, 55, 254, 257, 261, 262, 268 272
Replacement needle cage drive sprocket bearings for your chainsaw. We recommend replacing your drive sprocket bearing when changing your rim and drum or spur sprocket system. This sprocket bearing fits a crankshaft diameter of .5000 (12.7mm).
Fits the following chainsaws:
Husqvarna 40, 45, 49, 50, 51, 55, 61, 154, 254, 257, 262, 266, 268, 272, 340, 345, 346, 350, 351, 353, 357, 359
Jonsered 45, 49, 50, 51, 52, 410, 420, 425, 435, 451, 490, 521, 590, 625, 630, 670, 2041, 2045, 2050, 2141, 2145, 2149, 2150, 2152, 2159
Poulan 285, 305, 325, 330, 335, 336, 375, 395, 405, 455, 525, 655, 2700, 2800, 3000, 3300, 3350, 3400, 3500, 3700, 3800, 4000
Replaces Part Number 503 25 52-01
Thanks guys and spud! both my saws the 2065 and the 262 are used 8 hrs a day 5 days a week and i seem to be destroying them so fast! i broke my 3rd chainbrake band on the 2065 today and i dont use the brake as much as i should! tomorrow il service both and see what spare i need to buy next! So tempted to get a 560 though since its my living!
Yeah Rich, the 560 is a decent saw, very fast! Just spent the afternoon tweaking the ported 357XP to see if I can catch up with it - circa 0.4 sec faster on a three cut seven second run. Reckon it is possible - I was running a 2" longer bar at the time on the boys day out!
Glad the saws are making the wonga:thumbup:
