Chainsaw Mix N Match
adam_coverdale
As has been stated by pleasant there are many options avliable on most pro saws . Oregon manufacture a bar with xxxxxx09 as part of its part number . This bar will fit allot of saws in various sizes, pitches, and gauges . The main thing to be sure of is that the oiler outlet on the saw body lines up with the in feed hole in the bar . Look up on the Oregon site for options for your saw .
They will fit, as long as...
  • The chain pitch (typically 3/8", 3/8" Low Profile, .325") must match the chainsaw sprocket as well as the nose-wheel of the bar
  • The drive link gauge of the chain must match the gauge of the bar (typically 1.3mm = .050", 1.5mm = .058" or 1.6mm = .063")
  • The bar must match the chainsaw mounts and oiler holes must line up
