Lumbermate
  • Replies 29
I didn't have very good experiences with one that was kindly lent to me. I found the quality of the cut to be poor and it blew bands with a frightening regularity. Also, compared to the woodmizer, it's about 5 times slower.
I can speak only for my experiences, and I should stress that I am in no way set on Woodmizer (stop gap mill). However, the main thing that the Lumbermate did was set me on a hydraulic mill. Hydraulic log handling, as well as powered feed is the key to productivity.
On the topic of build quality, I found the headrig on the Lumbermate to be fine (bar the unsolved issues causing a band breakage every two hours of cutting) but the track was very flimsy.
Yeh..know what you mean.
I think all mills around this price will have issues though, they can only provide as much quality as the price allows :thumbup1:
I think as much as anything, they've built it to a weight spec. It comes in at under 750kg, so towable on any licence.
There just isn't enough steel in that to be rigid!
I have been using a lumber mate on and off for about a year. Other than the daft measuring scale that is a waste of time, it has proved to be accurate and easy to use.
I have never used a mill with hydraulics so i can not compare. If i had the money i would buy one tomorrow.
Sent from my Galaxy arse using Tapatalk 2
It's the speed of log handling that is key, especially on larger logs. To load, rotate, account for taper with toe boards and clamp take about a minute with the LT40. With the Lumbermate this would take at least 7 or 8 minutes. Then each time you rotate the log, you have to start again. I can see their appeal for economically converting timber, but you have to have a lot of time on your hands, as well as a lot of energy!
  • 3 months later...
Hi, does anyone know of someone who might want to sell a Lumbermate?
Yes I have one 3years old never been used,with trailer package 10 blades and blade sharpener robot and spare wheel it's kept in a shed under cover it is also built to spec
