  • Replies 28
White smoke is un burnt fuel, sounds like an injector has packed up, probably caused by debris from the pump failure. Be careful turning it too much, you can hydraulic lock it if enough fuel gets into the cylinder...
Could have an injector failed,if it's common rail system it won't hold enough pressure to make the rest work. Garage job either way.
The thing that made me think it's less likely to be an injector is that it now won't run. If you crank it enough they'll normally fire on three, even when the injector is dodgy. Not advisable to do it for too long as it can burn out the piston crown, which is another possibility, although again I'd expect it to start but just run really badly.
Alec
If one injector fails and leaks fuel pressure on a common rail system the rest of the injectors won't receive enough pressure to atomise the fuel. Hence the White smoke and now it not starting. Assuming it is a common rail system, im not familiar with the vehicle in question.
Not had problems with a common rail system (yet) - all my experience is drawn from older diesels. Current two are common rail though so I now have some new symptoms to remember.
Alec
If you have access to known good injectors aswell swap them and see what happens,might be worth a try before taking to a garage. Keep us posted with your results,
Alec
We are showing our age on this thread Alec.:blushing::biggrin:
