  mendiplogs said:
Hi all do any one run terra firma spring for 110/130 500kgs plus ones are they any good as can get springs made to take a lot more weight but they cost thanks all jon
Hiya John Iv got heavy springs and dampers on my 90 recommended by local Landy garage-can't fault them as opposed to stuff like Pro-Comp which Iv been told by the garage can sometimes shear off!:001_huh:
HI PETE thanks for that mate i think tommer runs on his thanks jon
  Sam Thompson said:
I'm pretty sure mind are TF off the top of my head. Terrafirma has a very good name though, so I imagine they'll be good
Sam
HI SAM thanks for that the I've order are 500kgs thanks jon :thumbup:
+1 for terrafirma here. Just fitted some +3" pro sport shocks and heavy duty coils to my d2. Far better ride than the bearmach blues that were on it even though they are supposed to be a heavier spring. They were actually shorter then the bearmach ones but gave more lift when settled. And they are handed like proper springs should be so a bit longer on the drivers side. Very good on price too, i found electric winch shop and LR direct to be most competitive for various TF bits. :)
Have had old man emu springs and dampers on the 90 for about three years now springs are progressive which helps with ride when empty but holds it up when laden, dampers are for a toyota pin to pin so had to change top mounts not had a prob towing fully laden up to now.
Edited by FLASH90
HI FLASH thanks for that mate i no emu are good:thumbup1: jon:thumbup:
Read more
