Your looking around the £24,000 plus vat with the length measure system for the 5-15B model, the next machine up is automatic and a bit more expensive. You need around 30-40 KW power so a standard forestry valtra/ valmet 6 0r 8 seires ot N or T range would be more than adequate.
The niab can handle stems up to 50cm which is on par with larger harvesting heads. It has a 2.5 tonne winch to haul the logs to the machine, (radio remote) and a long reach/ stroke arm. Have a look on the FORS MW web site for all the technical stuff.
  • 1 month later...
Hi,
I like the sound of that machine. Can you point me in the direction of some literature?
Cheers,
Andrew
you can download the brochure on the link below
5 - 15 B
video on link below
:thumbup1:
