I have a humongous oak tree to fell coming up soon in Wokingham
The trunk is around 6ft dia and 20ft high (virtually same dia all the way)
It is a crane job, but the trunk is going to be too heavy to lift in one.
What would be the minimum length for it to be of any use?
Cheers...Al
I'll have to go back and take some accurate measurements as a 120t crane will lift 5.5t at 30m, so don't want to get it wrong!
Al
HI AL what weight do you think is in the trunk mate jon or get bigger crane jon :thumbup:
Hi Jon
That is what I need to work out. 120t crane is the biggest that can get into the job.
I need to work out the timber weight next week.
Coming down your part of the country tomorrow to see my Mum in Ash Priors.
Cheers....Al
The other thing you could do is try and quarter it then transport it... As Jon says if you have a decent butt like this that is this diameter and that tall then it should be worth some cash....
Hi Rob
It's not possible to fell the trunk, can only go up and out by crane so quartering is not an option.
You'll almost want some of those boards they stick in the tree in the log type competitions - I've always wanted to know how they work.... must be more comfortable wielding a big saw from spikes.
