i am having difficulty getting my tree magic to fit comfortably and not pinch my privates ! does anyone who uses one have any tips ! or is it that the tree magic is not suitable for me ? in which case it will have to go . i suppose the million doller question is what to buy next , the only problem i have is that there is nowhere near to have a sit in one .
The leg loops need to be pretty tight to prevent testicular ingress.
I have heard the magic is bad for inadvertent castration though.
Are you not near Proclimber or Severnside?
You'll be lucky to find a TM anywhere at the moment. If you really want to find one, why not put a post up on here asking if there is anyone in your area who has one that would let you try it out.
I think the TM is the most comfortable leg loop harness around at the mo, although you may need some time to get it adjusted right.
i had one a couple of years ago that did crush me rocks, got another now, and its perfect! leg loops arent tight atall-loose enough to just slip in and out of without adjusting atall (couple of inch loose). the elastic from the back support to the legloops ive slakened off as far as they go, and the belt itself(the belt that runs across the back support and clips together at the front) is tight, and wear it across my hips-(not above my hip line like some do) infact same line my trouser belt would hang.
this setup for me, makes me not notice im wearing it!
hope this helps
