Hi all just wondered if anyone has had this problem, the ignition on my timberwolf keeps on switching itself back to 0 from 1 and switching off.
I remember using an old entec years ago that did the same but didn't do the maintenance on that machine at the time.
If anyone has experienced this before some advice would be good as I am not sure if it is a simple spring needs to be replaced or the barrel itself ?:confused1:
spray some wd 40 in it & turn the key to work it in ,if that fails its a new egy ,
Read more
